GangstaCowboy
- Joined
- Sep 24, 2011
- Posts
- 143
- Reaction score
- 3
Hello-
I have been trying to chase down some vibrations I have been having in my 2006 Tahoe. First I thought it was the AC since it would mostly happen when I turned on the air but slowly I started to feel it when the AC was off. I cleaned the MAF and air filter and there was no change. Last night I used some MAF cleaner and did my best to clean the throttle body while it was attached and un plugged the battery to do the idle re learn. So far there is a definite change in the way the vibrations feel, before when I revved the motor in park from 600-1000 rpm there was a weird wobble in the vibration, now it seems smoother. There still seems to be some vibration that I can't get rid of, not normal operating vibrations but random surges in the sound and vibration of the motor. Should I just replace the throttle body unit? Does it include the TPS and IAC in one unit?
---------- Post added at 10:45 AM ---------- Previous post was at 09:37 AM ----------
Also since I cleaned it last night when it is in drive and you take your foot off the brake it will creep forward up to 1100 RPMS with out hitting the gas, which it never did before.
