Throttle body relearn/high idle issues
I cleaned the maf sensor and replaced map sensor still same problem
still need to look at the other associated data, I have changed and cleaned and swapped throttle bodies I don't even know how many times over the years (lots) and never once had a idle issue. other people not so much luck. my guess is it is either still not learned correctly or something else is "off" a bit and causing it to think it needs to idle higher for whatever reason.
one guy went the wringer with his and had to re-learn it to the ecu, not just a idle learn.
