olyelr
The box is the xl version, whatever the cheaper newer model is (think the xt motion…cant remember).Nice! Looks good up there. I have the Thule XT Motion L in gloss black, basically the same as that one. Do you have an 8' garage door? Does the truck fit inside with the box mounted? I put mine on in the garage and need about 4" of head room to be able to get out with it mounted. Sort of annoying because I could go in and out with it mounted on my '19 Tahoe. Shows how much taller these new rigs are. My Yukon has air suspension so not sure if that makes a difference.
Edit: What tires are those?
Yes, we have an 8’ garage door and no there is no way in hell it will fit inside. Definitely sucks. Yea, these things are not only quite a bit taller than the prior model, but the cross bars sit up a lot higher too.
Tires are 305/45/22 toyo open country at3. I did level it, but they cleared just fine before the level.
