I have changed the CV axles and cleaned/inspected the balance of the drive train, nose to tail.
No codes are found when checked.
However, during slow, tight turns (left or right turns), I hear a rhythmic thumping sound from the front end that speeds up or slows down with the RPM of the wheels.
It's not entirely consistent, but I can reproduce the condition almost 90% of the time when I try.
The hubs didn't seem loose when I tested the wheel by rocking the tire vertically.
The suspension joints also seem tight during all attempts to rock/wiggle/twist it around using the tire and pry bars.
This is quite disappointing, considering I just changed the CV axles with good, high-quality ones.
I'll leave these in place because the previous axles were getting old.
However, I don't know what else to check to determine the cause of this thumping.
