ticking from the engine
992door
Greenville, NC
Does not do it on cold start only will do it after it warms up. It increases with engine speed. I can hear it sitting inside the tahoe. Sounds like it is coming from the passenger side
raptorforme93
Tampa, Fl
My hoe has the same thing.. Slowly developed over the last year and a half. Definitely more noticable on the passenger side than drivers. Is it possibly that the valves are out of adjustment and is that something that can be readjusted? Definitely sounds like a valve tick to me
992door
992door
Greenville, NC
OK will take the valve cover off and check to make sure everything is good up there. If not what could it be
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Rod or bearing maybe?
Oil pressure... does it maintain at least 10psi for every 1000rpm? It looks a little low, but not incredibly low for that engine.
Noise... could be as simple as a loose rocker. Easy fix. Pull the passenger valve cover, start the truck up and then slowly loosen the first rocker til it taps loudly. Tighten it slowly til it stops tapping and then go 1/2-1 turn more. Move on to the next until all 8 are done.
If the tapping never goes away during that process, it may be internal. Hard to tell specifically from that video though.
raptorforme93
Tampa, Fl
How do you check to make sure everything is in adjustment in the valve train?
---------- Post added at 09:42 PM ---------- Previous post was at 09:42 PM ----------
Sorry, posted right after JennaBear did
BurbyRST
