ticking from the engine
992door
992door
Greenville, NC
That video was not mine but cold start oil pressure is at about 40. Once it is warm and idling it is at about 20. Truck has 209k on it.
Rod or bearing maybe.
Hope not
But would the rockers make noise only after it got warmed up?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
if it sound like that video it is a bad rod bearing. especially if it goes away mostly when you pull the effected cylinders spark wire.
992door
992door
Greenville, NC
Could checking the compression help determine if it is a rod bearing. Wouldn't that cylinder be lower?
992door
992door
Greenville, NC
Will do in the morning
---------- Post added at 10:39 PM ---------- Previous post was at 10:17 PM ----------
What would be the best way to figure out which one it is just pull them one at a time then put it back pull the next and so on?
raptorforme93
Tampa, Fl
Just curious but why would disconnecting the wire tell if the rod bearing is bad even though the piston would still be moving with the rest? Relief of pressure from firing?
raptorforme93
Tampa, Fl
Damn, so if it turns out to be a bad rod bearing my hoe is definitely getting a big engine upgrade in the future!
raptorforme93
Tampa, Fl
Same here, I'd like to wait a bit longer before doing a total overhaul on the Hoe. One thing is certain though, Ill overhaul it ten times before I ever dream of getting a different truck. Let me know what you find out
b18cls1
