Timing chain set
Denalibro76
Replacing the timing chain set on my 2003 Yukon with the LQ4. Is it just a 1 pole reluctor?
Denalibro76
Denalibro76
Are you doing the oil pump at same time?
Yes. Full rebuild. There is a strong possibility that I will have to go oversize on the bore. Haven’t pulled the motor yet. Can anyone chime in if I can go up to the 6.2 pistons and not change the heads? Currently a stock LQ4.
Boring the LQ4 to 4.065" isn't unheard of, but it's kinda sketchy. Also, there are two different blocks and one of the differences is thicker walls. The block differences may have coincided with the change from iron to aluminum heads. It's been years since I've researched all this. It's probably okay in a truck engine kept at stockish RPM and power levels. If it needs boring, I'd keep it at .030" and get off-the-shelf overbore pistons. Them 317s will work fine. I'd recommend shaving them while they're off for a fresh and flat surface and to bump up the CR a little for some extra pep while still being 87 octane friendly.
Denalibro76
Denalibro76
Ok thanks!! Yeah I don’t like sketchy so I’ll probably just step it up a little . Maybe I’ll get really lucky and I won’t have to at all. Be nice to not have to spring for new pistons but I’ll most likely have to.
RAMurphy
Bob
Military
S. Maryland
As @iamdub already mentioned I wouldn't go above 4.03 if you need to increase bore. The engine I'm building is bored to 4.03 although I believe you could go higher (up to 6.2) based on my research. Whoever will do your machine work could give you better insight.
BrancoRST
