Timing chain set
Denalibro76
Denalibro76
As @iamdub already mentioned I wouldn't go above 4.03 if you need to increase bore. The engine I'm building is bored to 4.03 although I believe you could go higher (up to 6.2) based on my research. Whoever will do your machine work could give you better insight.
Yeah. I’m taking the necessary items to the machine shop to get the journals measured and all that stuff. So I’ll definitely be getting all the info I need.
Jnmbth
