Tinted front windows - Can it get removed?
DougAMiller
Colorado
The windshield has been replaced, but that is a Pilkington. They are an OEM supplier to GM, so I wouldn't be concerned about the quality. Not sure what to make of the frosted appearance, but it looks to me like it is an intentional pattern, like someone had it done for appearances.
X
xycrazy
It‘s surely not intentional. It shouldn’t be in that corner but at least it‘s not in the middle
91RS
GA
I’m only talking about passenger and driver side in the front. I want it like it came from factory as it’s too dark inside. I’m living in an area with winter… I’m getting depressed if it’s too dark lol
I guess to each their own. I won’t own a vehicle without tint, that’s usually done within a week of ownership. I don’t want people seeing in and it keeps the heat down because I do it on all windows.
DenaliCountry
Thanks for all the responses. Now that we're talking windows I figured other things which are very odd.
Would you please take a look at the pictures and let me know what you think what that could be and/or how to fix it?
I assume it falls under factory warranty as the car is still in warranty until October.
1. - there's like a frost pattern on the windshield in the right bottom corner (passenger side)
2. There's a rubber that comes off from one of the rear windows
3. It also looks like one of the front head lamps got replaced as there's this blue stuff and it doesn't fit 100% anymore.
What do you think?
I may be wrong, but that windshield looks like it might have tint on it and that bubble in the corner is the tint separating from the glass. Windshield was definitely replaced either way. Looks like the bumber under the headlight is not lining up either. Guessing it was in an accident which required the headlight to be replaced and possibly the bumper. Carfax won't show an accident if there was no police report and it wasn't reported to insurance.
X
xycrazy
Oh tha‘s a good catch. That might be true. I will have to take a closer look. Thanks for the hint!!
As for accidents: yes, we thought about that too, but the bolts of the head lamp are obviously not changed / moved. There‘s also no sign of aftermarket painting on the edges. However, what I read in the service reports is that they previously had issues with the daylight not turning off and they did something to it. I see they reprogrammed SPS (whatever that means) but I have no documentation about whether they had to replace anything.
CraftyCrafts
I’m looking at a used 2021 Escalade Platinum and it has tinted passenger and driver windows. I’m wondering if that’s from factory or if it can be removed. I didn’t see an option in the configurator.
Does anyone know whether it can be removed and how easy / difficult it is to do it? Thanks
Use a steamer and a blade. Just don't sit in one spot too long.
DenaliCountry
If the service department did replace the headlight, they may have installed the bumper incorrectly when putting it back together. My understanding is the bumper (and possibly the grille) has to be removed to replace a headlight.
WalleyeMikeIII
Sunny and Snowy Minnesota
The headlight “blue stuff” is a car wash brush that got stuck in the crack and tore off. This happens on my Denali occasionally too…from day 1, and it is perfectly aligned and fits perfectly…a consequence of the design not meshing well w/ a car wash…
But, a CarGax would show if there was any accident damage at all.
91RS
GA
Not necessarily. Carfax can only report what is reported to them and there are A LOT of municipalities and shops that do not report. Always check the Carfax but never assume that’s all the information.
wjburken
Eastern Iowa
Depending on where you live, tinted front side windows are just an invitation for law enforcement to pull you over. Here in Iowa, anything darker than factory stock tint is illegal. My wife was pulled over for it after we bought our last Yukon with tint already on the window.
kjetilaf
