whatever engineer decided to keep the engine as close to the firewall as possible, should have to change the passenger side plugs and wires on a 6.2 motor in under 30 minutes in order to keep there degree.
What a PITA those 2 rear plugs were, I had to access the furthest one back from underneath because the A/C lines, dipstick, heater lines, electrical wires and heat shielding prevented me from getting anywhere near it from the top. When I was finally able to get my socket on it, the exhaust only allowed me to turn the wrench about 1/16th of a turn, in order to get the plug completely out and started again I had to lie underneath the truck parallels to it and wedge my arm between the motor and hot catalytic converter in order to get my fingers on it.
Just a heads up, take off your gloves, rubber or fabric they just get in the way and get caught on all the square corners when snaking your arm up.
Tip number 2 is lay under the transmission parallel to the vehicle with your head towards the front and you can snake your hand up between the exhaust and transmission behind the sway bar and get your fingertips on the furthest plug
Tip number 3 is to use a wobble or if u have one a 1 1/2" extension on the 3rd plug back. The plug socket is too far under the head to get the ratchet on and a 3" Ext is too long because there's a heat shield on the way.
My dad taught me to start with the hardest one first and get that SOB out of the way.
Hope this helps for anyone in there future maintanence
