Tire and wheel Q's
bigmiker21
Central Ohio
I just picked up a set of GM CK916's for less than $500!! But i now need tires, locking lugs, and center caps. A tire retailer that stands above the rest? Also is it worth it to get the GM factory lugs or will after market ones work or are they junk? Appreciate any help.
---------- Post added at 01:05 AM ---------- Previous post was at 01:03 AM ----------
Also who has some bright LED reverse lights?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
get OEM chrome locks and lugs. They look the best inside of the wheel. I had aftermarket lugs on my ck375's and finally went to OEM and it's 100% better looking. Robbie (The Yeti) sells them and he is a vendor here... OEM Parts Direct and his link for the lug nuts (make sure you chose with locks) is here Wheels - Chrome Lugnuts
He can get you the OEM center caps as well
For bright LED reverse lights you can go with cree lights -
http://www.tahoeyukonforum.com/forum/showthread.php?t=45382
and
http://www.tahoeyukonforum.com/forum/showthread.php?t=39944
or something like this -
http://www.superbrightleds.com/more...-single-intensity-15-smd-led-tower/1514/3521/
or
http://www.superbrightleds.com/more...18hp-led-16mm-wedge-base-7440-tower-bulb/848/
Tahoe4neutrals
