I did some searching and haven't seen this addressed... I'll be lifting and upgrading tires. But to what is the question. Lift questions will come later, as I figure tire size -> lift size. No matter what lift I go with, the CV angles will run straight at rest, just like factory. I will not run any overextended CV for my intended use.
My use will be for a daily driver when we travel cross country in the summers, as well as a lot of trail riding, which can run the gamut from decent dirt forest roads to some of the middle rated trails in places like Moab and the Colorado mountains. Lots of washboard and potholes. If the Corona gets over with and we go to AK the frost heaves will bottom your suspension on paved roads.
So I want all the tire I can safely run, with reliability being job #1. I don't want to be replacing bushings or ball joints every year, and I don't want to snap a CV or blow the front diff, which my reading tells me is the weakest link. I won't be aggressively climbing rock ledges or intentional abuse, but there's time in the outback where stuff happens and trail conditions are not what you expected.
The contenders:
35"- I see a lot of GM half tons running these. Of course most of what I see is on pavement. I don't meet these trucks out on the trails very often. Is this tire size a recipe for snap-crackle-pop under adverse terrain and loads?
34"- most likely in 285/75/17. Not so many tire choices, but they're out there.
33"- 285/70/17. Seems to be a lot of IFS trucks running these with minimal leveling. I see this as the best choice for drivetrain durability.
So what do you say; what's your experience? Or am I in the wrong room and should I take this over to Pirate4x4?
The contenders:
