Tonyrodz's Tahoe Build Thread
wjburken
Eastern Iowa
I started to round it out, that's why I stopped. I was using a big adjustable too.
You are to the point that you need to soak that SOB in Kroil or PB Blaster overnight and then just commit to getting it out. Keep spraying either one while you are working on it.
You know that an adjustable wrench has it's place, but putting ugga dugga's into something is not it's place. I would strongly suggest you drill out the center of the sensor and see if that releases some of the binding. Then you put a 6 point deep well on it and with either an impact or a 24" breaker bar, alternate between tightening and loosening motions, work that damn thing out of there. You have to be more stubborn that then sensor and I am willing to bet you can be pretty damn stubborn.
I know you are afraid of damaging your collector pipe, don't be. Your choices are a stuck sensor, a potentially damaged bung that is fixable at an exhaust shop and a sensor that is out and then some threads to clean up and then put a new sensor in.
Dantheman1540
Sugar Loaf Mountain
I second the kroil best shit ever! You got this, a new bung is less than a $20 fix even if you really mess it up.
Dantheman1540
Sugar Loaf Mountain
I don't have any Kroil but I do have some PB Blaster.
Next $12 you have to spend on something dumb get a can it's like magic. But Blaster is great as well, tap with a hammer all around it after you apply the blaster. The side impact and vibrations work wonder on ball joints and I'm sure it will help in this situation. If you dont have the right size wrench go to harbour freight and buy it cheap. I have a bunch of odd sized wrenches that dont match any sets because I did the same thing and have mostly retired my adjustable wrenchs to hammer duty.
Sam Harris
Texas
I have an Oxy acetylene torch but before I had that I used one of these lil guys. worked well when I needed it, this would help you.
https://www.fleetfarm.com/store/detail/bernzomatic-welding-cutting-brazing-kit/0000000342883/5000
Definitely. You need a small torch at least! I probably have 4 or 5 nozzles around the garage and shed and a few bottles. Super convenient for many things. I think I paid around $20 for a kit with the nozzle and tank at Home Depot. Harder to get MAPP now unfortunately..
Jsuthe
