corvette744
2004 Z-71
Never mind i adjusted my gear box 1/4 turn clockwise and it made more difference than any part i have changed on the suspension to date.Best free mod i have ever done.Unreal steering now
Make sure to follow the advice in the thread about not over tightening or you could damage the gearbox. Never more than 1/8- 1/4 turn seems to be the consensus.https://www.tahoeyukonforum.com/threads/sloppy-loose-steering-fixed.46957/ follow this thread very simple to do-5/8ths wrench or 16mm and a 3/16ths allen and your done.Pop your hood and look down between your upper hose.
View attachment 203142 View attachment 203143
Thanks for the help!Make sure to follow the advice in the thread about not over tightening or you could damage the gearbox. Never more than 1/8- 1/4 turn seems to be the consensus.
Thank you for the help will do this tonight!!https://www.tahoeyukonforum.com/threads/sloppy-loose-steering-fixed.46957/ follow this thread very simple to do-5/8ths wrench or 16mm and a 3/16ths allen and your done.Pop your hood and look down between your upper hose.
unless your steering box is completely worn it it can definitely help.I have the same issue. Did this really work?
