too much oil pressure??
longstand
I have a 220k Miles Engine.. when i first purchase the car. the oil presure gauge was below the middle sign.
i change the oil with 20w-50 with lucas additive, now my oil pressure is over the half gauge.
is that ok..
SunlitComet
OBS Jedi-Do Good
unknown at this time.
According to your user manual it says do not use 20w-50 only 5w-30 or 10w-30 and do not use addittives. I would get that stuff out asap. Thicker liquid will offer more resistance to flow that would increase your pressure reading.
longstand
longstand
Well. yes. its very think for sure.. i had an idea.. i remove 2 quarts of oil. and add 1 can of Sea-foam. . the car will not be use for long haul everyday.. my wife will be driving it about 5 miles to work and 5 miles back or less ervery day.
i read about sea-foam being added to the oil. it will not harm gasket at all. its an oil base product...
SunlitComet
OBS Jedi-Do Good
If you only drive about five miles each way I would go with what the manual says and switch to a short-trip maintenance schedule. Additives are not a substitute for lack of maintenance.
Done Deal DR
I agree with both of your posts.
I'd be changing to the proper oil viscosity ASAP.
longstand
longstand
I wanted to start a New Thread. but no one ever answer me. LOL
What should be a Regular Oil Pressure for this Denali.
i heard 40-60 PSI when its COld
Warm Engine should be no loser then 18 PSI.
longstand
longstand
I average at 40 to 55 when cold and 35 to 45 when warm with over 220k on the original engine using chevron 5w-30.
My Denali Also has a 222k on the engine..
instead of using 5w-30 i use 20w-50 and added lucas.
my old pressure is 40 on cold and 45 warm.
i spend so much money on the oil including the lucas. i dont know what to really do.. the car runs good. but the oil pressure is a little bit over the middle on the gauges.
i started a thread before and everyone told me to change OIL ASAP. with 5w-30. which i have purchase. but i dont know if i should really change. the engine runs good.
I been checking around google.com and this forum. i have no clue what really is the OIL pressure suppose to
IRQVET
2 Door Owners Club
Tallahassee, FL.
When I first brought my Tahoe to my new(er) mechanic last year, he noticed my oil pressure was a bit high and asked me if the truck had a high performance oil pump. I was running 5W-30 Mobile 1 Full Synthetic at the time.
I switched to 10W-30 Mobile 1 Full Synthetic w/ Lucus oil additives (1 Qt.) and now my oil pressure has leveled out.
It's strange that I had to move toward a higher weight oil to lower my oil pressure, really weird, but it worked, lol.
Keep in mind, my Tahoe only has 91K so that may make a difference. (Shoulder Shrug)
Chadricckglenn
