brucebanner
- Joined
- Oct 23, 2015
- Posts
- 2
- Reaction score
- 0
I did a scan on my 2010 Yukon SLE today and I have a few failing test. Any input would be appreciated thanks.
Code:
Mode $06 report generated by Torque for Android
Vehicle VIN: 1GKMCAE36AR227910
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: 126
Test report:
MID:$01 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
Max: 0.45018V Min: 0.45018V
Test result value: 0.45018V
PASS
MID:$01 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
PASS
MID:$01 TID:$03
Low sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.30012V Min: 0.30012V
Test result value: 0.30012V
PASS
MID:$01 TID:$04
High sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.60036V Min: 0.60036V
Test result value: 0.60036V
PASS
MID:$01 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 120ms Min: 0ms
Test result value: 29ms
PASS
MID:$01 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 120ms Min: 0ms
Test result value: 24ms
PASS
MID:$01 TID:$80
Max: 65,535Changes Min: 40Changes
Test result value: 136Changes
PASS
MID:$01 TID:$81
Test result value: 133Changes
PASS
MID:$02 TID:$8a
- O2 Bank 1 Sensor 2
Max: 590Count Min: 0Count
Test result value: 228Count
PASS
MID:$02 TID:$8b
Max: 2.04936V Min: 0.77531V
Test result value: 0.82118V
PASS
MID:$02 TID:$8c
Max: 0.13993V Min: 0V
Test result value: 0.07845V
PASS
MID:$02 TID:$91
Max: 0.45018V Min: 0V
Test result value: 0.44689V
PASS
MID:$02 TID:$92
Max: 2.04936V Min: 0.35014V
Test result value: 0.35453V
PASS
MID:$02 TID:$93
Max: 8 Min: 0
Test result value: 0.62
PASS
MID:$02 TID:$94
Max: 8 Min: 0
Test result value: 0.58
PASS
MID:$05 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$03
Low sensor Voltage for switch time calculation - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$04
High sensor Voltage for switch time calculation - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 2 Sensor 1
Max: 120ms Min: 0ms
Test result value: 32ms
PASS
MID:$05 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 2 Sensor 1
Max: 120ms Min: 0ms
Test result value: 25ms
PASS
MID:$05 TID:$80
Test result value: 122Changes
PASS
MID:$05 TID:$81
Test result value: 124Changes
PASS
MID:$06 TID:$8a
- O2 Bank 2 Sensor 2
Test result value: 226Count
PASS
MID:$06 TID:$8b
Test result value: 0.79337V
PASS
MID:$06 TID:$8c
Test result value: 0.10248V
PASS
MID:$06 TID:$91
Test result value: 0.39565V
PASS
MID:$06 TID:$92
Test result value: 0.36234V
PASS
MID:$06 TID:$93
Max: 8 Min: 0
PASS
MID:$06 TID:$94
Max: 8 Min: 0
Test result value: 0.53
PASS
MID:$21 TID:$a0
- Catalyst Monitor Bank 1
Max: 0.99939 Min: 0.3498
Test result value: 0.98567
PASS
MID:$22 TID:$a0
- Catalyst Monitor Bank 2
Test result value: 0.98545
PASS
MID:$35 TID:$b0
Max: 200Count Min: 0Count
Test result value: 0Count
PASS
MID:$38 TID:$30
Max: 409.70001 Min: 5,641.7002
Test result value: 2,893.1001
FAIL
MID:$3a TID:$c0
- EVAP Monitor (cap off)
Max: 14L Min: 0L
Test result value: 4.366L
PASS
MID:$3a TID:$c1
Test incomplete or dependant test failed
MID:$3c TID:$c8
- EVAP Monitor (0.040")
MID:$3c TID:$c9
MID:$3c TID:$ca
Max: 1Count Min: 0Count
PASS
MID:$3c TID:$cb
PASS
MID:$3d TID:$c4
- EVAP Monitor (0.020")
Max: 6,553.5S Min: 45.6S
Test result value: 45.6S
PASS
MID:$3d TID:$c5
Max: 2,500Pa Min: -8,000Pa
Test result value: 56.75Pa
PASS
MID:$3d TID:$c6
Max: 60S Min: 0S
Test result value: 2.5S
PASS
MID:$3d TID:$c7
Max: 40L Min: 10L
Test result value: 10.008L
PASS
MID:$41 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 8Count Min: 0Count
PASS
MID:$41 TID:$d3
Max: 2.481 Min: -4.211
Test result value: -0.507
PASS
MID:$42 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 2
PASS
MID:$42 TID:$d3
Max: 2.481 Min: -4.199
Test result value: -0.105
PASS
MID:$45 TID:$d2
- O2 Heater Monitor Bank 2 - Sensor 1
PASS
MID:$45 TID:$d3
Test result value: -0.546
PASS
MID:$46 TID:$d2
- O2 Heater Monitor Bank 2 - Sensor 2
PASS
MID:$46 TID:$d3
Test result value: -0.119
PASS
MID:$71 TID:$8d
- Secondary Air Monitor 1
Max: 41,012minute Min: 26,816minute
Test result value: 6,624minute
FAIL
MID:$91 TID:$33
Max: 2 Min: 20,561
Test result value: 13,200
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
Test result value: 4Count
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
Test result value: 1Count
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
MID:$a8 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 7 Data
PASS
MID:$a8 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 7 Data
PASS
MID:$a9 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 8 Data
PASS
MID:$a9 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 8 Data
PASS
MID:$b1 TID:$8d
Max: 41,000minute Min: 10,432minute
FAIL
End of report.
