Does anyone know what the torque Setting on Rear caliper bolts 2004 z71 Tahoe?
I looked up the FSM and it does not make any sense. I have the JH2 Brake hyd. power setup. The FSM only talks about the front knuckle (caliper mounting bracket to knuckle) torque setting of 129ftlb.
There is a setting for:
Caliper mounting braket to backing plate, rear (jc5/jh5) 148 lb ft
Caliper mounting braket to backing plate, rear (jc6) 122 lb ft
I went with the 122 lb ft as it was the lesser of the two and was concerned of over torquing.
Additionally, is there really a reason to use locktite? I see some people go with the blue. Mine came off fairly easily so I assume the mechanic who worked on it in the past did not use locktite. They were all held at different torque settings (based on how hard each bolt was to take off.)
