TPMS not accurate. How to recalibrate???
20Tahoe21
My 2021 Tahoe RST tire pressure monitoring system ls not accurate. It reads about 3 to 4 psi less than actual pressure measured with 3 different gauges. The 3 gauges are all within one half psi of each other. All 4 tires are off by the same 3 to 4 psi. Is there a way I can recalibrate this myself? I get an On Star email every day saying my tires are under inflated and they are not.
I reckon that the module would need to be either re-programmed or replaced. Why don't you sneak around back and ask the techs at your local dealership? That's what I do.
Fireman591
Michigan
Sounds like a warranty issue. Take it to the dealership and have them all replaced. This is nothing new for GM lately. Many of the parts coming in from GM's vendors during this pandemic are failing or not working as they should.
Yukon, OK
Are you cross-checking these pressure numbers immediately after adding air to the tires? I seem to remember reading somewhere that the TPMS does not instantly update after adding/removing air from the tires and that the vehicle must be driven a short distance before it's updated. Personally, I add the air based on my hand-held TP gauge then drive it a few miles then check the the TPMS values the next day before I drive it to see how close they are. They have always matched or been within 1 psi for me. Just something to check before you jump through hoops with a dealer over this.
This! ^^^^ On mine, they often take more than a few minutes to talk to the truck's computer, especially when it has been shut off and the sensors gone to sleep.
hardnett
