Traction Active
PG01
Up here to the right
And truck is fine besides this noise/msg? No codes or cel? It drives fine, no loss of power? has the transfer case or front differential ever been serviced? (Fluid changed). If it is saying traction active and you hear noise down by the front right of truck either your front diff is low on fluid or the drivers hub is bad. Its prob the hub.
H
Hunter
Had the truck in auto today had the same noise but Traction Active did not come on. The noise is down by the Steering column I think it’s some kind of motor not a Diff noise or transfer case noise
Timbers
Not sure if this is an issue with the 2006 but my 2000 had a similar problem when braking under 5MPH the ABS would come on. Its because the ABS sensor in the wheel hub gets pushed out of it's bore hole because of rust. You just take the sensor out of the wheel hub, stick a piece of paper towel down the hole and wire brush the rust off the face of the wheel hub where the sensor fits on. Put some anti-seize on it and then put it back. It brings the sensor back to its original position which is close enough to the timing wheel in the hub to read wheel rotation and your ABS should work properly.
Again, I'm not sure if this is a problem with the 2006, but its something you can use to check if you are out of ideas.
DMG48
Any other lights on the dash like the triangle with the exclaimation poi nt in the middle?
It could be a Steering Position Sensor if so.
Klayton R Benac
Driver side hub is bad. You here a slight whine when driving?
I am also having the traction active problem and I am getting whining gurgling sound when leaving stop sign. And I do believe my hub is bad. I think you are right just haven't had the time to mess with it.
06Z71TAHOE
I have 2006 Tahoe with Digital Dash notifications. When I leave from a stop the abs module kicks on and the Traction Active Message comes up on my dash. Any help is much appreciated. The noise is only for a few seconds and the Traction Active message is also only for a few seconds. Thanks (At least I think it’s the abs module kicking on) No abs light comes on
What did it end up being? I'm having the same issue now
Tjf2222
