No whine at all. Hub bad or just sensor ?Driver side hub is bad. You here a slight whine when driving?
Im no mechanic but it sounds to me like your hub is bad. 2wd or 4wd?No whine at all. Hub bad or just sensor ?
4wdIm no mechanic but it sounds to me like your hub is bad. 2wd or 4wd?
And truck is fine besides this noise/msg? No codes or cel? It drives fine, no loss of power? has the transfer case or front differential ever been serviced? (Fluid changed). If it is saying traction active and you hear noise down by the front right of truck either your front diff is low on fluid or the drivers hub is bad. Its prob the hub.
Had the truck in auto today had the same noise but Traction Active did not come on. The noise is down by the Steering column I think it’s some kind of motor not a Diff noise or transfer case noiseAnd truck is fine besides this noise/msg? No codes or cel? It drives fine, no loss of power? has the transfer case or front differential ever been serviced? (Fluid changed). If it is saying traction active and you hear noise down by the front right of truck either your front diff is low on fluid or the drivers hub is bad. Its prob the hub.
I am also having the traction active problem and I am getting whining gurgling sound when leaving stop sign. And I do believe my hub is bad. I think you are right just haven't had the time to mess with it.Driver side hub is bad. You here a slight whine when driving?
What did it end up being? I'm having the same issue nowI have 2006 Tahoe with Digital Dash notifications. When I leave from a stop the abs module kicks on and the Traction Active Message comes up on my dash. Any help is much appreciated. The noise is only for a few seconds and the Traction Active message is also only for a few seconds. Thanks (At least I think it’s the abs module kicking on) No abs light comes on
