Traction control and stabilitrac
jlschef
I have a 2012 Yukon and the traction control and stabilitrac DIC lights are on. It only has 60k miles and it runs fine. There is no hard shift, no lack of power, no abs or check engine lights. Any idea what might be causing the issue?
Kraig
Those lights come on anytime there's a problem. Get it scanned for codes.
conchasjim
My 07 just threw the same code, along with a hard shift, then check engine light. Started idling rough also. Ran the codes and said misfire on number 6. Checked plug, wire and coil and all checked good. Cranked the engine without starting and was a bit off. Mechanic thinks it's a broken valve spring. Anyone have an idea?
randeez
south florida
Check brake fluid level also...had a bad bleeder screw in one of my back calipers when fluid got low enough it would kick on those lights intermittently
For OPs problem...misfires are a whole not her issue lol
Lilmule
