Trailer brake controller on 09 Denali?
doubletapdrew
It looks like it has been done, I found this:
http://www.dieselplace.com/forum/showthread.php?t=245484
I went and snapped pics of the master cylinder on a 2011 Denali we've got in stock with that option, and my 2007 Denali (without that option obviously) to see the differences. Looks like the master cyl and brake booster are different
2011 with JL1:
2007 without JL1:
However I took a pic of an identical 2011 without JL1 and it looked the same as the one with the JL1 option so maybe at some point (like when that became an option) they changed the master cylinders/boosters
2011 without JL1:
I'm interested to find out how easy or difficult it is to retrofit it if you do this!
S
stevek
Dallas, TX
2011 with JL1:
2007 without JL1:
2011 without JL1:
I'm going to try to see what needs to happen for this
zach2011
Platinum Member
Looks like a neat part, but programming your truck to a different VIN will seriously cause some issues. However, there will be less issues if you happen to find a VIN from a vehicle exactly like yours with this added option. There should not be a problem with that, but dealers aren't always willing to do this.
Either way, good luck on getting it installed Steve, if you go that route. Keep us posted.
S
stevek
Dallas, TX
Wait doubletapdrew you work at a dealership?
I have the same master as your 2007. Why would I have to get my VIN reprogrammed?
S
stevek
Dallas, TX
Parts dept at one dealership said it couldn't be done but he seemed a little stupid. The actual button was $3x.xx, the harness was $3xx.xx and a few other things. Then he said something about having the wrong frame. Who knows... aftermarket here I come.
doubletapdrew
Yes I work for a GMC dealership. I think it needs to be reprogrammed to play nice with the ECM (basically tell the truck it now has a brake controller) since the factory brake controller displays info on the DIC and the master cylinder tells the unit how much brake pressure to apply to the trailer brakes since it's electronically variable.
I've never heard anything about a different frame unless he's thinking about the 2500HD trucks with that option, but since the option can be had on light duty trucks, they haven't changed the frame since 2007 as far as I'm aware (except for the 2011 HD series but that's a whole different animal).
Why does it have to be so complicated? I'd like to rip the whole kaboodle out of one of the new trucks and see if it'll work in my 2007 but I don't think our GMC sales manager would like that much, haha.
I'll go see if the parts dept. has any ideas.
---------- Post added at 03:14 PM ---------- Previous post was at 02:57 PM ----------
Ok both the parts dept and shop said they don't know if it can be done and haven't had any requests for it yet. The shop manager said he'd have to look into all that's required to do it and figures GM recommends an aftermarket controller because it's not cost effective to swap the factory one in. I'd agree, someone listed the parts required on another forum and it totalled something like $1,100 in parts alone (plus however many hours of labor it would take to install and get it working correctly).
Anyway, I had good results with the Tekonsha Prodigy aftermarket brake controller in my 2007 2500HD! haha. It was about $100 or $120 or something and pretty easy to install.
FSUDAVE
Any update on this???
I've searched everywhere and still haven't found anyone who has successfully done this. Except for the guy who spent $1000 in parts. I just bought a 2011 Tahoe LT with trailer package but no controller. I'm hoping that since they are now available as an actual option, that most of the parts would be the same. It looks like you need the knee bolster, switch and brake relay. My only problem is that I can't locate the plug near the back that goes into the relay. So I'm thinking you may need a whole new wire harness?
Has anyone else come up with any new information? Thanks!
