Trailer Brake???
toms99
According to my owners manual, there is an 8 wire hookup under the back end in front of the rear bumper mounted to the crossmember for a trailer brake. What is this and how is it used? Does this thing have some kind of a built in trailer brake or is it a wiring harness make installing an aftermarket brake easier?
dsltrc
Virginia Beach, VA
Tom, there is no prewired trailer brake option in our trucks but I did write how a how to when I did mine... http://www.tahoeyukonforum.com/forum/showthread.php?t=26505
---------- Post added at 07:33 AM ---------- Previous post was at 07:27 AM ----------
And here is a kit sold by advance auto parts:
http://shop.advanceautoparts.com/we...n-Kit-Hoppy_22260003-P_2329_R|GRPLAMPAMS_____
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Trailer Tow
Exterior Lamps
Notes
62392344
Trailer Tow
arb905
If you have a trailers with electric brakes, you will need a brake controller in order to activate the brakes properly. I ran a single wire to the rear and spliced it into the electric brake spot on a 7-way blade connector. Then find the brake light only wire under the dash and connect to the controller and run a power and ground wire to the battery. I have had no problems since I hooked it up.
pewtermetallica
