Tranny Questions
P
project96
I had a scanner it was throwing P0102. I messed around a little bit, cleaned out the MAF but it ended up just being a fuse! Should of checked first but yeah thanks for all the help guys! Cheers!!!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
if it is the eng-1 fuse and it keeps blowing out on you chances are a heater circuit in an O2 sensor is shorting out or you pinched the harness when putting tranny back in.
retorq
Kingman AZ
Did that on my firs clutch replacement in my 86 K5 Blazer ... you only do something like that once!! Took a month to track down ... Come to think of it, that is actually one of the last times someone other then me has worked on my car, the issue was the choke fuse kept blowing ... the mechanic's solution was to put in a 25 amp fuse where a 15 should have been.
daddy g
