transfer case noise
yukonGT350
recently i put my truck in four wheel drive just testing it out and once engaged the noise from my transfer case seemed pretty loud.... any ideas on what problem could be.. note: i havent checked fluids on it yet
Y
yukonGT350
correct, no noise in 2wd, and its the same amount of noise in high or low, i may change fluids today to see if that helps
SunlitComet
OBS Jedi-Do Good
unknown at this time.
It is most likely then that the shifting mechanism is not completing the shift. If new clean fluid at the proper level does not help smooth it out the case will need to be opened for inspection.
---------- Post added at 01:37 PM ---------- Previous post was at 01:36 PM ----------
BTW, :welcome:
Dave6137
