davidbeaver1
I have a dilemma that I hope some can help me with. I have a 2005 Tahoe 4x4 LT with 159K on the clock. A couple of weeks ago, I ran into the dreaded transfer case "pump rub" and had the back half of the case replaced with the stronger case. I got the truck back and everything seemed to be fine. I then took a trip where speeds got up to around 80 mph, standard interstate speeds. When I stopped, smoke surrounded the truck. When I looked underneath, the transmission was leaking on the cross pipe and it was leaking out of shifter seal.
So I took it to my trusted mechanic and he replaced the shifter seal and the vent hose on the transmission but when testing any speed above 75 mph, the transmission now builds enough pressure that it is blowing the seal back out and starts leaking again. I think it is odd that all of this started after having the transfer case repaired and I had no issues with it before the transfer case repair. I drive many highway miles at 75-80 mph.
Anyone know what would have changed that would be causing the transmission to build up enough pressure to blow out seals? It is the original transmission. Thanks for any insight you can provide.
Very Frustrating....
