Transmission help!
Kemo13
Wondering if anyone put a tranny from 2000 suburban to 2000 yukon denali? Or is that transmission not compatible with my yuk.
The torque converter bolt holes seem to a quarter inch or so off either flexplate holes. Have the holes in the flexplate drilled out to match torque converter? Do i need a flexplate spacer as well?
As an Amazon Associate we earn from qualifying purchases.
01ssreda4
The trans itself is the same, and will interchange. On some of the early iron block engines they had a long crank snout which would make the flexplate different. But basically all 99-06 transmissions interchange without issue.
K
Kemo13
So i need the flex plate adapter? New flexplate? Or a tc that will mate with the flexplate i have on now?
mateo1120
