Transmission interchange???
O3YUKONXL
Found a little info but need to be sure. Can I swap a 4l60e into a 4l65e yukon? I have a 03 Yukon XL SLT ( built 6.0 ) with real fresh 4l60e with a kit and v servo. Want to put that transmission only into my 04 Yukon denali. Direct ??
rockola1971
Indiana (formerly IL)
not sure what is different from the 60 to 65 but generally speaking 03-06 are compatible, @iamdub @swathdiver
4L60E -4 pinion planetary
4L65E -5pinion planetary wider 2-4 band, 2-4 servo more holding power. A 4L65E is essentially a upgraded 4L60E and a 4L60E can be upgraded to 4L65E specs. A 5 pinion planetary drops right in place of a 4 pinion planetary.
Chllinone
