transmission replacement
TheKid_eric
Camp Lejeune
I am wondering how hard it is to change a 4L60E to another 4L60E, trans now has internal failure by not going into reverse. is it basically just unbolt, and then bolt the new back in?
ezdaar
Chat Troll
Redneck central, Aka Houston
yes. borrow or rent a "trans jack"
Look for the bolt on very top of bell housing.
You will need about 3' of extensions and a swivel that has been tapped with electrical tape to kep it from flopping around.
#1taho
5150TAHO
niagara falls ont
Are you handy with tools ?
If your handy and have a friend help you it is a really easy job. You should be able to have it out and back in the same day.
#1taho
5150TAHO
niagara falls ont
If you do it your self there are two plugs on the drivers side that are glued in. Get a hair dryer and heat the up. It is a slow process but if you don't hear them you will break wires and the $100sensor they attach too.
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Extensions extensions extensions. Or ideally a 3 foot long 1/2" drive female to 3/8" drive male extension for the top two bell-housing bolts after you have removed the trans cross-member and lowered the tail of the trans down a bit. Not a tough job but the right tools make it easy.
ccapehartusarmyINF.(ret)
Gilbert AZ
also you must have no less then a half rack of beer on ice in the cooler that is if you live down here in az were its warm i suppose if you live up north you prolly just toss the beer in the snow
TheKid_eric
TheKid_eric
Camp Lejeune
i live in NC its not been bad, but at 17 i dont think beer is gonna slide with my parents. thanks for the imput guys really helps.
2006yukonxl
Whoa..I guess TheKid_eric is 17. Impressed. In that case, get all your friends involved and have
a pool party after.
llisumm
