lowpapasmurf
I have 99 Yukon SLT. Every time I stop and let off the brake to go I get a clunk which I originally thought was a U-Joint, a rear shock loose, or the Axel sleeping on the Springs. It's not any of those as far as I can tell. So I think it is in the Transmission. When It attempts to shift down to 1st gear after coming to a stop. Lately, I have started getting the clunk when I slow down just before I stop as well or instead of after I let off the brake, so I am pretty sure it has to do with shifting to low gear. I have checked the transmission fluid which is full at hot, as it is supposed to be. So my question is... is this the torque converter or something in the transmission? Obviously I am sure I will get some relief if I drain the tranny, replace the filter and fill it back up again without needing to dropping the whole tranny but has anyone experienced this and how did you fix it?
