I am planning to do the fluid change only (not the filter) by opening the drain plug at the bottom on the trans pan this evening.
Does anyone know the volume the stock trans oil pan holds?
I want to pick up some A/T fluid on the way home and want to how many qts I need to get. I checked the owner's manual but it doesn't specify. Also, is there easy way to drain out the remaining A/T fluid in the torque converter without dropping the pan?
