truck will not start need help asap
1lowhoe04
Fort Worth Texas
just replaced fuel pimp and fuel filter and checked main fueses and all goo turn key and pump doesnt turn on and try to turn over and turns over but does not fire
MeanGreen03
TX
Have you checked to see if there is any power going to the pump?
THE-HOE
Pittsburgh Pa
If the pumps not turning on then it cannot be getting power. If you say all the fuses are good then I would make sure to check your fuel pump relay. If you had a short in the wire you could have melted the relay. Replace your pump relay with another one in the electrical center that is the same as it and turn the key on just to see if it kicks on.. If it does then you just need a relay.
If it doesn't I would go unplug the wires from the sending unit and turn the key on and see if there is power going back to the sending unit. If you have power at the plug to the sending unit then you know your wiring is all good, if you don't then its time to start following the wires back checking for problems.
chip
Tampa
+1 Good Post!
Administrator
"The-Hoe" brings up some good advice :High 5:
1lowhoe04
1lowhoe04
Fort Worth Texas
yes amazing advice aand allready did all that before reading lol
i melted alot of wires looks like a wire fire under fuse box melted wired going inside to dash area then wires melted going to alternator and thats done and idk about the injectors yet
sooooo i NEED a wiring harness asap
Administrator
:whymewhyme: doesn't sound good! I'm glad the fire wasn't worse that that :eek:
chip
Tampa
That sucks Balls! See if there is already a recall on yours first.
AceDawg
