Truck won't crank
nonickatall
Germany
I have a problem with my truck. it won't crank.
I had that problem a month ago as well a few times and I swapped the battery, after that it didn't happen again.
Today I helped someone who had a problem with his car. His battery was empty, so I bridged his battery with my battery while my engine was running. I checked the other car for error codes and noticed that my engine was had stopped for whatever reason.
After that i tried to crank, but nothing happens.
I thought first: My battery is low and I put on a charger.
The battery is new and now full and when I turn on the ignition, I have normal lights in my instrument cluster.
When I switch to start, I have the lights going away, like normal.
But there is no crank, so I first removed my right wheel and measured at my starter, if current is available. I can measure ground to ground and I have 12 Volt at the power line, from the battery.
On the line which controls the magnetic switch of the starter, there is no 12 Volt, when I let someone start the truck.
So I looked for the starter relay. I swapped the starter relay with the equal relay next to it, with "park lp", whatever that means. No change.
So I looked for the description on the relay and I measured between 87 an 86, but there is no current, so it seems that something else don't work.
I tried to bridge 30 to 85 but the starter don't crank as well.
When I switch on the ignition. There is this sign with the lock. I'm not sure if that is always there.
Does anybody have an idea, where I can start to search for the problem?
Best regards from Germany
Ralf
Scottydoggs
NJ
the fat cable to the starter should always be 12 v hot. the small wire should show 12 v when the key is turned to crank, its the trigger wire. so if thats got power the starter is not working, if its not getting power it could be something like the starter relay, or the fuse box melted under the relay, or the ignition harness in the steering column has gone bad.
CG11
