Tune voided my Yukon warranty
well that just sounds annoying as hell anyway you look at it. glad i dont live in cali.
I have read somewhere there are mobile stations they place on the freeway on ramps, it has a camera and a sensor, when you drive by it if it get's a bad wiff they flag you via the license plate number they snapped a picture of. not sure if that is in California or not
91RS
GA
I love when people just start shouting Magnuson Moss in threads like this and have no clue what the act really does. The Magnuson Moss Act does not cover you for aftermarket performance modifications or tunes it requires manufactures to honor their warranty against factory defects and not require you to use a particular brand of parts or service. Changing of the vehicle’s configuration is not covered under the warranty.
Tiredmechanic23
If your changes have 0 effect on the parts failed as in it literally did not or could not cause that failure then yes the MM act can protect you. At that point the failure is still a FACTORY defect. Yes if you up the redline then throw a rod or wipe a lobe that is on you. But if you say tune your trans then that AFM lifter not pumping up and wiping a lobe is not your issue as that still a defect. You are right it covers FACTORY defects unless your changes could or did cause changes in the factory parts working. The MM act has held up and helped many.
Fortunately local dealers here other than our local Ford dealer do not even try to deny warranty for programmers/tunes or even bolt on mods. They will attempt to void for a tune if they find tuned it and screwed up though as in you played with tables yourself trying to learn. Both my local GM dealer and my local Ram dealer encouraged the use of a tune to improve MPG and towing and stated it would not bother warranty unless someone obviously screwed something up. Hell my local Ram dealer didnt even care that my 2500 ran red only for the first half of its life.
Ford here on the other hand do not like to even touch a stock vehicle under warranty or recall if they can avoid it. My brother is fighting them with a focus right now.
A nice quote for you.
"In a Consumer Alert issued by the Federal Trade Commission (FTC), the agency confirmed that “The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket part.” The alert outlines key provisions in the law that provides protections to car owners. As defined by the FTC, an “aftermarket' part is a part made by a company other than the vehicle manufacturer or the original equipment manufacturer.”
“The FTC’s reference to aftermarket parts is equally applicable to specialty parts,” said Russ Deane, SEMA’s General Counsel. “Under the Magnuson-Moss Warranty Act, the warranty cannot be conditioned to a specific brand of parts, services or vehicle modifications unless those parts or services are provided free of charge.”
The alert notes that a consumer has the right to patronize independent retail stores and repair shops for parts and service without fear of voiding the new car warranty. The dealer/vehicle manufacturer has the right to deny a warranty repair but they must demonstrate that the aftermarket part caused the problem. The warranty remains in effect for all other covered parts."
They have the right to Deny the coverage but if fought which can be expensive then they have to prove the correlation. The act does not state you can just scream MM act at the service writer and it they suddenly jump and fix it and say okay. But it does provide a option to fight to keep coverage. Often times it will not be worth that fight. A denied warranty repair for something like HP fuel pump really wouldn't be worth it. But a denied warranty for a engine and transmission replacement after the flywheel bolts sheer and everything gets trashed (unrealistic example scenario) would be worth it.
91RS
GA
You can put bolt-on aftermarket performance parts on (such as headers or a cold air intake) and generally be fine but if you open the engine or tune it, you’re done. GM states a tune voids the warranty and that’s the end of it. They are allowed to do that under the Act. You have to follow the rules or you risk your warranty.
In saying that, a dealer only HAS to check for a tune to replace a major driveline assembly but they CAN check because they suspect something. It is also up to the dealers discretion and also who gets involved. Many dealers will be “nice” and just tell you they won’t fix it because of X modification but not submit it to GM to block the warranty. If there is some crazy problem and a field engineer gets involved, it is out of the dealer’s control. If your dealer is cool, that’s great but they do not have to be. In this case, the OP needed an engine and therefore they were required to check for a tune.
Yep, glad that I live in NH. You have to really be out of bounds here with exhaust systems, for law enforcement to become even slightly interested.
autochampoftexas
