Turbo Tahoe?
09TahoeLT
Did everything mount up no problem? Like the inner cooler? I saw some people having to make there own mounts for it
ibfreeman88
ibfreeman88
Chesapeake, VA
The kit comes with brackets for the intercooler which worked well. But to be honest if I were do it again I'd probably go with the trick performance kit for simplicity and what seems to be more quality parts in regards to V band clamps and T bolt clamps etc.
mikeyss
Longmont, Colorado.
I think the 2009 Tahoe had the option to have a 4.8, if it was 2WD. The 4.8 would have had a 4L60. I found this as well:
2009 CHEVROLET TAHOE SPECIFICATIONS
  • Price (MSRP)
    $ 36,965
    Value Rating
    N/A
  • Engine Name
    Engine: V8, 4.8 Liter
    Transmission Name
    4 Speed Automatic w/Overdrive
  • Trim
    LS 2WD
    Class
    Full-Size SUV
  • Horsepower
    295@5600
    Standard MPG
    14 City / 20 Hwy
  • Body Style
    SUV/Crossover
    Drivetrain
    2WD
  • Fuel Type
    Unleaded Regular
    Seating Capacity (Std/Max)
    6/9
ibfreeman88
ibfreeman88
Chesapeake, VA
Someone went through a lot of work to backfit the 4-speed in there then, even the TCM had to be changed, should be a T43.
My truck does in fact have a 4L60e and it came from GM that way. M30 on the RPO codes.
ibfreeman88
ibfreeman88
Chesapeake, VA
Definitely an odd one! I know the 09 trucks split the year between the 4L60 and the 6L80 (I was a tech and a parts guy for GM) and every 09 Tahoe 5.3 had a 6L80, while the 4.8 2WD only had the 4L60. I bet it's a very early 09.
I was really hoping I was going to get lucky lol so then I could skip the 4L80 swap and go straight to a cam and converter lol. But I'll just make due until I get all the trans swap parts in hand.
Odd and unexpected! Tenth digit in VIN is "9", designating it as a 2009. "LMG" is the 5.3 and, as you already know, M30 is the 4L60E. Oh well, with enough power and with a good shift tune, you won't miss the other gears so much.
Well I'll be a monkey's uncle! Never heard of that before. I read where the pickemups started out 2009 with 4-speeds but not the SUVs. Guess it might have had something to do with it being a PPV maybe?
GT4 = 3.73 gear, that's good!
brian70068
