Turbos or Supercharge?
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
my dream for the silverado would be to put a twin screw SC and then a turbo on each side.
BOSS
The People's A D M I N
Dallas
yes you can
that's what want.
B
---------- Post added at 07:38 PM ---------- Previous post was at 07:36 PM ----------
Supercharger to help get our heavy suvs off the line and moving quicker. The boost from twin screws and roots style s/c start from low rpms and build a nice flat torque curve. A centrifugal s/c and turbo don't have the lowend torque like roots and twinscrew s/c. On a lighter vehicle, I'd say go with a turbo or centrifugal. The power potential is greater at higher rpms. But on our big SUVs, I'd go twin screw or roots s/c. Chistoso has a Whipple, which is a twin screw design. I'm running a Magnacharger, which is a roots-style. Both are great units and have insant torque off the line.
I understood from reading that the IAT is higher on a whipple because the Magnacharger has some type of cooler on it?
B
Max
Mile High
Denver
B
Most well designed supercharger systems will incorporate a heat exchanger to keep the intake air temperatures down. The cooler and denser the air is the more power the truck will make, higher iat's can cause all kinds of gnarly stuff with too much timing. Methanol injection will dramatically drop the intake air temps, I plan to run both a heat exchanger as well as a healthy dose of water meth. Consider the heat exchanger to be the supercharger's radiator:
O3YUKONXL
O3YUKONXL
Thanks for the answers so far !
Good info. What else will I need w/ the charger; immediately? And what can wait? ex, tranny build, injectors ... ???
tybardy
everyone needs a Hoe
Gilbert Arizona
just chiming in here, where can i go to read info on the different types of SCs (preferably all in one place)
Max
Mile High
Denver
There's a huge sticky over at pt.net regarding the different forms of forced induction which covers the pros/cons of each.
witty_name
