Turn signal flasher location?
00WhiteLS
OK my issue is I put some LED bulbs in the front turn and park housing. When I use my turn signal they blink fast. The front and back bulbs work so nothing is out but I was told I have to change my flasher to an electrical version flasher. I pulled a location of the flasher and it says it is around the fuse box on the side of the dash. The flasher is clicking but I can't norrow it down as to where it is exactly. Anybody changed it that could give me some help?
chistoso
Arizona
You need to run load resistors on those LEDs. If you wanna go the flasher route, it's under the dash on the driver side. You need to remove the lower dash cover under the steering wheel. I'll try and get a pic for ya. Gimme a bit..
B0$$MAN
Boss of all Bosses
Chicago, IL
You have to run resistors because LED's take almost no power to run, therefore your stystem thinks that there is nothing there or that a light bulb is out; a resistor consumes that power so that your system thinks something is there.
00WhiteLS
Do I have to connect the resistors to a certain wire on the turn signal? Do I need to have a certain amount of resistance?
B0$$MAN
Boss of all Bosses
Chicago, IL
You can buy small resistors in a pack for cheap and just trial and error from that point cause I can't remember what load the turn signals require/take. You have to connect them to the power wire on your wiring harness leading to the turn signal bulbs.
00WhiteLS
Thanks, I'll try it out.
greenhornet
Ontario,Canada
The point of LED's is for less power consumption and heat ,longevity and color. it makes more sense to change to an electronic flasher rather than loading down the system with heat producing resistors.just my thoughts.
jomulk56
Resident Lurker
IN
Old thread revival. Who has the brand and part number for the flasher relay? I found it on advance autos website a month ago, but I've forgot it since then. I really would rather do the relay than resistors if at all possible.
newjonwayne
