Turn signal LED resistor...
Smoove
South Florida
So, I learned the hard way that I need a resistor of sorts for my LED turn signals that I just installed in the back of the ride yesterday. lol. Fortunately I didn't do the fronts yet cause the HIDs haven't showed up yet.
Does anyone know who sells, or where I can find the what I need? It only makes sense I would need one on all four corners?
Thanks in advance. I did a search but, only thing I found where escalade tail light conversions.... which is another want lol. Not now though, already spent enough.
Thanks again.
vt_hokie2008
VA
Seems easy enough. 1 for each corner obviously right?
Thanks for the link!
Yep, one for each. I've only done the fronts, but it was one on each of those.
Btw, they get pretty hot, so it's best to mount them somewhere that they won't melt anything around them. Mine are actually hanging below the headlights behind the bumper where they don't touch anything.
And you're welcome!
Smoove
Smoove
South Florida
And you're welcome!
Awesome VT...thank you!
One last bother,...the 1 x 6 ohm 1 x 6 OHM 50W 2 BULB LOAD EQUALIZER RESISTORS LED TURN SIGNAL BLINKER FIX | 1 PAIR
or
1 x 3 OHM 50W 4 BULB LOAD EQUALIZER RESISTORS LED TURN SIGNAL BLINKER FIX | 1 PAIR
I ment to ask yesterday but forgot. :smoke2:
yOGi420
Are these needed for the LED tail light replacement bulbs that would fit into the stock light bulb sockets (found on ebay) or for a different LED taillight?
Administrator
They are needed for any light that flashes whether rear or front yes
GMgarbage
