Turn Signal Out?
Rivieraracing
When you say you checked all of the fuses, did you actually check them all or just one the ones that said they were for the signals? Check every single fuse there is to check in both fuse boxes, the one by the drivers door in the side of the dash as well as the one under the hood on the drivers side if you haven't already. GM piggy backed many circuits upon each other and often times will blow an unrelated fuse due to a different labeling!
If you do that and still nothing, then I'd find the relay and see if that's messed up, then look at the signal switch in the steering column!
F
FreeTime
Lansing. Michigan
Yes, I went through the whole box inside and under the hood. Pulled and checked everyone.
Today, I will find and check the relay as recommended
Thank You!
Rivieraracing
Yeah, might be the relay but more than likely it could be a broken/chaffed wire or the actual signal switch going bad! Check around the steering column for any wiring that is touching anything that moves or turns!
JochenWoern
Sacramento, CA
As mentioned earlier, my thoughts as well.
If it is the relay, you would think both side would not be working.
Bigjohnny
