TheBigler
Can’t get my left turn signal to turn off or my emergency flashers to engage. I tried changing the flasher relay but no luck. Could it be the turn switch itself or something else?
Multifunction switch controls so many functions, I'm thinking that is your culprit. I had an issue that I would hear the ticking constantly without the turn signal selected. It would stop ticking when I pressed the brake, and then start again when I let off. Lol. Here is my original post. Good luck.Seems like the multifunction is likely the cause from how many videos there are of people having to change it. I’ll see if I can find anything wrong with wiring first!
Just a heads up, those wiper issues are often resulting from cracked solder joints on the wiper motor board. You can usually reheat the solder or add a touch more, so it might be worth a quick check. There are probably YouTube repair videos that will show the common failure points.I am changing my multifunction switch tomorrow. My problem is the windshield washer won't spray (tested the motor and is working), and also if I turn my wipers on for a misty or light spray from the road, the wipers take like 5 minutes to go off and even then they sometimes stop in the middle of the windshield. And the cruise control is spotty. The switch does so many functions I am surprised it doesn't have some type of failure more often.
Thanks. I am not able to physically do the work myself anymore so I have to pay someone. But if there is an issue after the switch change I will look into it.Just a heads up, those wiper issues are often resulting from cracked solder joints on the wiper motor board. You can usually reheat the solder or add a touch more, so it might be worth a quick check. There are probably YouTube repair videos that will show the common failure points.
I can attest to this fix as well. Done it once and it was a successful, permanent repair on (1) of the (4) rigs of this generation I've owned.Just a heads up, those wiper issues are often resulting from cracked solder joints on the wiper motor board. You can usually reheat the solder or add a touch more, so it might be worth a quick check. There are probably YouTube repair videos that will show the common failure points.
Edit: video for future reference
