I was given a 98 yukon. Ive got it running but I've had issues with the dome lights always on. Ive swapped all door push pins, hatch glass push pin, and new headlight switch assembly. Only way to get dome lights off is by pulling the fuse. Which I have done.
Took today to get inspected for first time since 2017. Passed with no issues. On way home I noticed the turn signals would blink once or twice then freeze on when i used them. Light went off when I turned signal off. If I tried the other side it would immediately freeze. I'd wait 5 minutes and try again and that pattern would repeat.
Got home. With truck running, turn signal now goes straight to freezing on when I activate stalk.
I notice that with truck OFF but in ON key position, signals work flawlessly. As soon as I start truck, issues reappear. AND NOW the dome lights won't come on at all.
Any ideas?
Any ideas?
