Two .062 Crack Heads.
retorq
Kingman AZ
It's called a freeze plug... who rebuild the block?? Why is that missing?? There are others and if they forgot those they may have forgot others ... like the one at the back of the cam or the three behind the timing cover ... I need some more periods in this... post ...
longstand
longstand
Its not Freeze plug. i dont think. It has a thread inside. so someting needs to be Screw into it.. I have no idea what goes inside it..
longstand
longstand
Here is a picture. thats the Driver Side
SunlitComet
OBS Jedi-Do Good
unknown at this time.
raul that looks like the starter in the first two pics. and if so that screw hole you may be referring to is actually the mounting hole for the Knock sensor.
longstand
longstand
Are you sure. its a Knock Sensor. Because I have installed all sensors on this car...
But just to make sure. i will check if i miss any parts.
SunlitComet
OBS Jedi-Do Good
62392465
longstand
longstand
Got the Engine started. Reset the Engine CODE. Car Starts Great. it RUNS Great.
But, i have a P1345.
its a rebuilt engine.
Warm the engine for about 20 minutes, and reset the engine code again.
but the P1345 comes within 1 minute.
I will check the CrankShaft Sensor see what happen.
The CrankShaft Sensor is good. from what i remember. if it was bad Car will not start.
Maybe i just need to adjust the Distributor.
longstand
longstand
zero out the cam_retard with a scanner.
What. never heard you could do that.
The only Reset feature i know is Reset the Code. but never heard i could reset the Cam_retard with scanner
I will see if my Equus 3100 could read Cam_Retard
Rome58
