They should come pre-greased, so no grease needed. I would go to autozone and rent (it's free but, you pay a refundable deposit ) their ball joint press (It's just a big c-clamp that works almost perfectly for u-joints). I used it because I dont have a shop vise and even if I did, I dont know that I would have wanted to put that much pressure on it. They aren't designed to be presses. If you do have one, it's would be best used just to hold the drive shaft while pressing the u joints out with the ball joint press. All that means nothing if you have a hydraulic press though (but not many people do).
I'd also pick up some type of torch (propane is probably the cheapest). The torch really isn't needed and I didn't use one but, it probably would have made things easier (see below for more info on why it's easier).
A u joint strap kit might also be worthwhile if you think you might strip the bolts on the straps trying to get them out. They are cheap enough insurance against a future headache. I rounded one of mine and probably will have a heck of time removing it in the future if I have to.
There are a bunch of u-joint tutorials already out there on the net. The only difference between most of them and on our trucks is that GM used an injection molded plastic to keep the caps in place instead of clips. That's where the torch comes in handy. Just apply heat to those caps instead of removing any clips before pressing them out.
Sent from my SM-G920P using Tapatalk
Do you have any pictures of what that plastic looks like? And just to be clear, you dropped the driveshaft completely out of the truck and then used the press to remove the caps and get the U joint out?
I actually picked up a 6 inch C clamp from Advance on Sunday when I was changing my rear brakes. I was planning on either using that or going with the "hammer and socket" method like this goober:
Final question: is there any difference between the front and rear U joint? It doesn't look like it, but I ask because all of the U joints on amazon say
This product fits this position on your 2008 Chevrolet Tahoe:
- Rear Driveshaft at Rear Axle
