Ugh emissions emmissions
DallasTahoe
So now I'm having issues getting mine inspected, already been to the inspection place 5 times the first four times because it said O2 sens not ready and egr says not ready, they said maybe because it hasn't been driven much since disconnecting the battery. So I drove it around on the freeway and the streets and was able to drop the EGR off the list, now it's just the O2 that's not ready. Do I just need to drive it some more or do I need to go more in depth on it? Really tired of spending money on her
DallasTahoe
DallasTahoe
So I tried again at the inspection this time it turned on the SES light so went to autozone, they pulled the code p1153 HO2S-21 (bank 2 sensor 1) insufficient Switching, and since I can't pass because of an o2 sensor showing not ready I'm going to replace it and hope this is the issue, any thoughts?
DallasTahoe
DallasTahoe
use a delphi or delco sensor. you should be fine after if that is the only code.
I put in a Bosch, good brand for only $41.99 and it passed inspection, I couldn't be happier
LAWDAWG4993
