Denali_WA
About a two months ago my Yuk Denali was having issues charging & maintaining a charge. So I went combing through the threads on here looking for ideas to to correct the issue. First, I replaced the battery with a better battery. The issue still was existing and i was noticing that my voltage was dropping from 14v to 12v depending on the engine load. Then I decided to upgrade the grounding and main power distribution wires to 0awg, known as the Big 3. After that mod I was still having the same issue with the voltage dropping. Lastly (which i thought would be the fix), I replaced the factory alternator with a high output, 250 amp alt. And still having the same issue I am at a loss now as to what could be causing the voltage issue.. Anyone have any ideas??
