Unhooked Battery, now it won't start- Please help! *SOLVED*
Brandon2489
I believe I recall seeing a tsb about unhooking battery the wrong way and it may damage the bcm. I will see if I can find it.
Brandon2489
Here you go. Looks like what you may have disconnected was a ground path for the BCM.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Good find. I saw that too but wasn’t sure if it applied to the work the OP did. I didn’t look at it much closer.
I guess it comes as a reminder to always disconnect the battery before unplugging modules and such.
S
Scrapman
According to that tsb, I did it correctly. I removed Only the negative battery cable, and the tsb says to do it first.
S
Scrapman
ahhh,,, wait. Unless your saying the latch's plug contains a ground for the BCM....Then you hit the nail on the head.
Sadly, I don't have and couldn't find an electrical diagram to figure this out. Towing it to the only mechanic I trust today.
CaptainAmerica1
Arlington TX
This is what did it
intobaitem
