RockGlock86
- Joined
- Feb 2, 2019
- Posts
- 40
- Reaction score
- 39
So I have a 2007 Yukon SLT with 5.3 LMG AFM motor, currently at 155k. Last november had it in the shop and they pulled the driver side head and replaced intake and exhaust lifter on No1 as the AFM lifter had separated and the spring portion was kinda falling off. So afterwards it runs great and back on the road. About June this year starts having the same issues and symptoms but now its Cyl 5 misfire, not an AFM Cyl. Figure its time to delete AFM anyways if I am doing further work.
So I used a Northern Auto parts AFM delete kit without cam, Summit 8718 Cam and 3 bolt timing gear and ARP bolts, Black Bear ECM/TCM. Reassemble engine and fires up no problem and runs fine for 5 minutes or so and starts a tick which transitions to a loud knocking sounds over the next 5 minutes. Coming from the driver side bank, around No 5. Not sure if it is 5 though, might be 3, I cant isolate the exact location of the noise.
Turn engine off pull valve covers and inspect drive train and everything looks fine. I only installed new lifters, used same push rods and rockers. Run engine with cover off and everything looks as it should. all push rods are tight, rocker arms are not bent or loose, valves are all tight and opening and closing as they should. Now noise it down to a slight tick like my 2000 6.0 2500, so i figure its fine. take it for a test drive and the sound comes and goes several times, in and out from a ever so slight standard tick to a hammer sound back to a tick. On initial startup it ticks while it pumps up pressure for maybe 5-10 seconds, probably need a new oil pump or O-ring in the pickup tube. Then the it makes no noise initially, as engine warms up the tick shows up and it most prevalent when engine is hot. Oil pressure on initial start up is <5psi for 5~ seconds then goes to about 35 psi. Under acceleration at over 2k rpm it will raise to 40-45psi.
I have done everything I can think of to quiet a noisy lifter short of removing the head and changing the brand new lifters on the driver side. Pulled the rockers back off and sprayed chemtool down the pushrods, fired it up and it sounded super quiet and smooth and that lasted about 3 miles then back to tick/knock. Changed the oil and used liquimoly MOS2, lasted about 5 minutes of idling and went back to tick/knock. Seafoamed the upper engine through the brake booster hose, sounded good for about 5 minutes of idle and then tick/knock.
No codes, misfires, hiccups, runs and drives great actually the only issue is it makes a loud knocking noise intermittently. I feel like if I had a louder exhaust I wouldn't even notice it.
I have owned loud diesel trucks and know that those engines are very noisy and sound like a typwriter. I have read that there are TSB's about Chevy engine noise. this seems louder than usual, and louder than the truck ever was before. but now that its deleted I'm not sure what its supposed to sound like.
So I guess my questions are,
Is it possible to have just installed a crap lifter?
Is it possible that Cyl 5 has some issue that sounds identical to lifter knock.
What else other than lifters could cause this issue?
Is it something else entirely and has nothing to do with lifters?
Whats the best way to diagnose the problem?
Thanks for your time guys.
Justin
Justin
