Upgrading my brakes
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
Ok so i got the rear rotors on and it looks great! Wasnt too bad either. Now to get the mechanic to put the brakelines on and change the fluids....
Heres the old vs new rear rotors
Sent from my DROID4 using Tapatalk 2
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
Phil you said the rear wasn't to bad.....care to ellaborate on what you mean.
The rear wasnt too bad to replace. Wasnt that hard. Felt like alot more room to work as well. The only annoying part was the little metal things around the lug nut bolts that kept the rotor pushed back. Dont know that they are called exactly.
Hammered Avy
Good afternoon everyone, I wanted to put this out there for Leonidas, since no surrender is the Spartan way. Below you will find the part numbers, retail price and 15% off price of the correct parts for your truck.
Premium Series Double Cross Drilled & Diamond Slotted Rotors:
(Black Military Grade "E" Coating Corrosion Protection)
Sold In Pairs
Front Part # PDS.66057 $200.98 (15% Off Price $170.83)
Rear Part # PDS.66065 $165.98 (15% Off Price $141.08)
Eline Series Drilled & Diamond Slotted Rotors:
(Zink Corrosion Protective Coating)
Sold In Pairs
Front Part # EDS.66057 $188.98 Retail (15% Off Price $160.63)
Rear Part # EDS.66065 $155.98 Retail (15% Off Price $132.58)
Posiquiet Ceramic Pads:
Sold As Axle Set
Front Part $50.99 Part #105.10920 (15% Off Price $43.34)
Rear Part $39.99 Part #105.11940 (15% Off Price $33.99)
Example Order:
Front Premium Double Cross Drilled & Diamond Slotted Rotors $170.83
Rear Premium Double Cross Drilled & Diamond Slotted Rotors $141.08
Posiquiet Ceramic Brake Pads Front Axle Set $43.34
Posiquiet Ceramic Brake Pads Rear Axle Set $33.99
TOTAL SHIPPED PRICE (Within the Lower 48) $389.24
TOTAL SAVINGS FOR THIS PACKAGE $68.70 OFF The Full Retail Catalog Price!
Is it possible to still get this Great deal for an 07 Chevy Avalanche?
:popcorn:
02TAHOEswitch
