So, anyone have any tips for getting the bolts out of the upper control arm? Tackled the passenger side tonight and when trying to break the nut loose on the front bolt I busted the bolt at the nut. I got the nut off on the rear bolt but man I could not get those suckers to move at all after putting a wrench on the other side and trying to spin and beating the hell out of the end of the bolts and the control arm.
I was able to get the tie rod end switched no problem and as soon as I got enough material ground off the lower ball joint a couple whacks with the hammer and I got that sucker out too. New one went in like a breeze with the press tool. Had to use some heat to get the spindle mount off of the lower ball joint.
What I thought was going to be the easiest part to remove is a *****!!
I have an 09 Yukon Denali, 117k and has seen a salty Wisconsin winter every year.
I don't have a cutting torch or anything fancy like that, just some pneumatic tools and a grinder. I soaked the shit out of those parts with penetrating oil 24hrs before messing with it. I'm about reserved to get what I can get done and put it back together and get it towed to the local shop and eat the cost to have them do it with an alignment. Should have just gotten wheel bearings right away, the one I have off now makes some noise so going to order some of those up while I'm at it.
Thanks.
Thanks.
