upper corner light mod
the big blue bus
the big blue bus
richmond, va
i cut the old sockets out of my stock corners. planed to just drill hole for the bulb to fit and cut grill out for it and to glue th ring the socket twists into on the back of corner. yeah i saw yours too and its what made me want to do it. i just dont know if it will look good being my lense is clear and you will be able to see the hole but at night it would look good like yours. as far as th side lights idk im not going to put running boards on. i think the leds in tow mirrors will be enough for it.
the big blue bus
the big blue bus
richmond, va
doing it right now.. will have pics on how i did it and night time pics later too! hardest part is hackin grill up and drillin hole to size i dont have bit big enough. and need to jb weld the ring on or something
SunlitComet
OBS Jedi-Do Good
unknown at this time.
when in turning or in hazard mode the corner lights are wired to alternate with the main turn signal lamp filaments in front. And facebook not working how about youtube.
the big blue bus
the big blue bus
richmond, va
they work fine in turning. hazzard was a little werid. ill get a vid when its a lil darker
heres one picture.. if anyones interested in how i did it i can post them
video
http://www.youtube.com/watch?v=Hl6z_0rDXuM
SunlitComet
OBS Jedi-Do Good
I see now. How did you wire them in?
---------- Post added at 06:08 PM ---------- Previous post was at 06:00 PM ----------
You have apparently wired them in such a way that the flasher unit may be cycling like a bulb is out when hazards are on. you could replace the flasher with a led compatible/ non-load sensitive type. You could alsowire them just to the lowere wattage filiment of on parking light circuit and they will just stay on as long as light are on but not change whe turn/hazard is on.
the big blue bus
the big blue bus
richmond, va
did them the same way haks did his just taped into the other corner bulb. blinkers are acting normal but i thought hazzards lookd funny. i could try the diff flasher
SunlitComet
OBS Jedi-Do Good
Blue bus, you have two flashers and the are both thermal types so if you do the one on the convenience center that should be the hazard flasher. It is seeing more load and as a result the bimetal thermal switch is trigering more quickly. An electronic/(type I mentioned above)should solve the problem.
Chadly14
